Captain Caveman
- Mar 1, 2005
- 1,027
My 2009 Suzuki DF90A was on the fritz this weekend. I was 20 miles away from my cabin when the low voltage alarm went off. It turned over but wouldn't start, tilt/trim wouldn't work, etc. I disconnected everything from the battery, cleaned all of the connections, tightened everything, squeezed the fuel bulb, checked all of the fuses, and got it to fire and went the 20 miles home. The voltage meter was pegged at 14. As I approached my dock at idle speed the motor died.
I charged the starting battery that night but the next day but it still turned over without starting. While diagnosing, I decided to try the choke lever. If I pulled it up, my motor would start and idle wildly. At half "choke" it settled down but if I put the choke lever all the way down, the motor would shut off. Since you can't shift into forward or reverse with the choke lever up, I basically had a motor that would idle but go nowhere.
I used my electric trolling motor to get it back to the public landing and onto my trailer. I threw a new marine starting battery in but it still wouldn't start. Now it's at the shop to get diagnosed.
Long story short, what does the choke do? The dealer originally advised not to use it because it is an EFI - which made sense. I've never touched it in 12 years of use. Now that I see it was the only way to get the motor to start in a no-start situation, I am curious. What is that choke lever actually doing with my EFI motor?
