Yes choke is closing on initial start. More throttle engine still dies. Do you know of any fuses hidden in the line.Being a GL it should have a Holley carb. Check power at the coil and see if its going to zero when motor shuts off.
Is the choke closing on initial start?
Can you keep it running by giving it more throttle?
did you check fuel pump pressure AND vacuum?Replaced fuel pump. Any suggestions?
