What are the Volvo penta designation numbers found after the 5.7?
Most likely it's fuel injected vs being carbureted?..Just making sure is all.
By Mike Halligan, Sales Representative All Volvo engines come from the factory with a metal tag riveted on the engine or outdrive which has the serial number and the engine identification. From the late eighties and up, the serial number should be ten digits in length. If you can provide us...
blog.marinepartsexpress.com
muldermotoren.com
Most times without the help of a marine designed scan tool like seen below, these intermittent symptoms are extra challenging to find especially if it's 1 of the catalyst sensors...
Just an idea to consider, sometimes in the craigslist website you can find mobile marine services that may have a scanner to go out with you for a ride...
Look under
services for
marine and see if that may help in your area.
Good luck.
