The Force power
- Feb 3, 2019
- 2,358
YUP, better of rebuilding an original than swapping it with a Chinese. lolLots of Chinese crap out there-shop wisely
When you energize the choke, do you have full power at the terminal of the solenoid ? if yes, do you get any voltage-reading on the body of the solenoid ? If any significant reading is present, that would mean the solenoid is not properly grounded.I bought the starter on Amazon, so you could have a point there. Although both starters were/are doing the same thing....I can pull apart the old one and see what my options are. I did lube the shafts on both starters with 3 in 1 oil as well and worked it through the system.
Are you saying cables inside the starter being backwards? Because I'd read elsewhere on here that putting the battery cables on backwards and the like would not result in this necessarily. I'm happy to check the innards of the old starter to see what they look like.
Thanks to all for the feedback; I would take this to a mechanic honestly but I can't find one who will actually work on it. Everyone claims that Force parts are so hard to get but so far I haven't had an issue with it and I'm probably not needing the clutch dog replaced either, merely simple electrical parts most of which I have already replaced.
Also, I replaced the key switch last night and I have to double check the wiring because it was juuuuuust starting to get dark when I finished it, but it had zero impact on the choke or the starter.
Also, would a loose or disconnected ground wire somewhere under the console do this? I can spend some time checking through for that.
Thank you. Excellent advice and I'm going to run out right now and use the last bit of daylight to check this stuff....When you energize the choke, do you have full power at the terminal of the solenoid ? if yes, do you get any voltage-reading on the body of the solenoid ? If any significant reading is present, that would mean the solenoid is not properly grounded.
Also check all the ground terminals under the helm & under the Cowl.
Bypass both battery-cable and use booster-cable to verify IF INDEED your battery-cables are good
Yup-been there…ONCE!WELLL????
My first Mercury I switched the cables and couldn't understand why the bendix wouldn't lift![]()
ssst, he's still sleepingWELLL????
.my arms aren't long enough to engage the choke and also hold the voltmeter LOL.
If I'm understanding correctly and your saying with one probe on the chocke solenoid ground itself and one probe on the negative battery post you get 0.3v? With it energized of course? That sounds about right, there will always be a bit of resistance in a circuit, 0.3 volts in that run sounds healthy. Also as far as the ground side of the entire circuit on an outboard goes. One cable will come from the negative post of the battery and usually bolt directly to the starter. This effectively grounds the starter and all other circuits will usually be grounded in different places off the engine block. So ground cable, starter body, engine block, then all other accesories are grounded off the block. Sounds like you have the ground side down pretty well. Of course a voltage drop test between the starter case and negative terminal will completely rule that out. Next I'd look to do the same tests on the hot side of these circuts. It works in the same way. It's also a useful check of starter solenoids. Put it across both high current terminals of the solenoid then crank, it should show very little voltage if your contacts are working well inside. If you take a minute to really think about how it works, simply measuring how much voltage the unwanted load (high resistance) in any given circuit is eating up. Then you can really apply it to most anything your dealing with. The 6 v across the pins of the solenoid mean the solenoid is only "using" 6 volts out of the 12 or so fed to it from the battery. So we know that .3 v of that are being used by resistance in the ground side, very minimal and normal. But where's the extra 6 v going? Has to be lost somewhere between the positive battery post and the positive side of the solenoid. So repeat those steps on the positive side of the circuit until you pinpoint the extra resistance.OK here's the verdict on the choke.
When I hook the red to the choke power and ground the black, i get about 6 volts at the choke when I push the key in. When I put the red on the body of the choke and ground the black, I get .3-.4 volts when I push the key in. From what you guys are telling me, and my own electrical knowledge, I believe that means for sure loose ground on the choke. My question is can I run a second ground somehow to alleviate this or must i hunt down the original loose/bad ground?
ETA: I'm looking at my Haynes manual wiring diagram, where/how does the choke solenoid ground to begin with? Does the fact that the choke doesn't work mean that loose ground is actually on the choke or could it be anywhere? I also tested the resistance from the post on the choke to the body and it falls within spec per the manual, so choke is functional.
10v when I turn and hold in "start" position.Is that 10v when the key is turned to start and the starter is running or is it just when the key is pushed in to activate the choke only while in the run position? If it is the first then I would suspect the starter is drawing current and a slight drop in voltage would be normal. Don't know what that starter is supposed to draw amp wise but if you have a way to measure the amperage and compare it to what is spec that could answer a lot of questions. Bad starter or an engine being too tight could be two thing to check. Pull the plugs and check the voltage when the starter has a light load. If you have a kill switch pull the lanyard or be sure the plugs are grounded to avoid possible damage to the ignition system.
Edit: SAFETY NOTE If you cannot disable the ignition be certain the plugs are not near the plug holes where a fuel air mixture are being expelled. I am sure many of us have made that mistake at least once.
when it's hooked to solenoid and key is turned to start attempting to crank engine.10v when it's disconnected or hooked to the solenoid?
