Here is the scoop. I got a fantastic deal from an older gentleman that I work with on this 1990 Blue Fin Spectrum 17’ aluminum deep v boat. It is the 1706 model. However I’m facing a drawback. The serial # plate attached to transom mount is completely faded out. I can make out the manufacturer, but when it comes to model # and serial # those are like empty boxes.
I’ve scoured the internet looking for casting #’s, hidden second serial #’s and so on with little to no luck. I have found numbers but when researching them they don’t return a valid result. I have called Mercury Marine outboard and talked with some great folks over there but they and the people that have been around for awhile couldn’t come up with anything either. I’ve seen in some forums to use a black light and it should illuminate the numbers but it hasn’t worked. Any ideas, locations, and general help would be greatly appreciated.
here’s what I have for numbers and the basic location:
from the title: AR430BXC as the manufacturers is #.
719518 - from the back side by plug #1 on the head
719 - from the top of the block
906061 - or 190906 (depends on which way you look at it) from below the flexible exhaust outlet
H 0 355 - near the bottom of the block stamped horizontally
P756L28 - rotated 90° on the back of the block by the H 0 355 marking.
hull id #: BFFA12JBF990 affixed to starboard side of transom per the norm.
any help would be appreciated, thank you.
I will send photos as I can.
