mlewis0113
- Jul 29, 2020
- 16
I have a 1997 Glastron GS186. I purchased it last July only to find out it is a bit of a Franken-boat. I've had to fix numerous issues that th previous owner either didn't do correctly, or not at all. The boat originally had a Volvo 4.3 I/O but currently has a Jasper reman Mercruiser 4.3(with no serial number) and an Alpha 1 Gen 2 outdrive.
The issue I have is with the engine running, regardless of if it is on the water, when I turn full left, the steering binds and is a fight to get it back into power steering. Full right it goes to the stop and I still have assist. I have verified that the cable is free when it is disconnected and I can go lock to lock on the helm. Also, with the steering arm completely disconnected, I can easily turn the outdrive both ways as well.
The only thin I noticed that was odd, at full left with the cable disconnected, the end for the pin is partially in the steering tube. I'm slowly learning about boats as I work on this unexpected project and am at a loss here. Thanks for your input,
Mike
Mike
