San_Diego_SeaRay
- Nov 9, 2014
- 343
...and now I just ruined the 4th one....
Happy 4th Weekend. Hope everyone is enjoying themselves!
Long story short:
My question is: Looking at the pictures I've attached and the history of ruining impellers, do you think the housing has as much to do with the problem as anything? There are groves in the walls but there are no cracks. I should also say that the lower housing hose (the outlet) was leaking a small but steady (drip drip drip) amount of water. No matter how much I tightened the hose clamp, it continued to drip. Thanks in advance!
Long story short:
- Boat hasn't been in the water >4 years due to a bad gas tank that had to be removed from under the deck and replaced (my projects are stretched out for maximum fun
- Over the course of those 4 years, I have variously attempted to run it on a sketchy water supply although it should have been adequate for the low RPMs (it was off a 500 gallon water tank that recycled the water. Didn't have access to an actual proper water supply)
- I had so far ruined 3 impellers and replaced them
- On Tuesday, I finally towed the boat to a proper water supply and ran it. It ran great. Sucked up all the water and didn't even hint at overheating
- On Wednesday, I dropped her in the water and she overheated while at the dock to 225 degrees
- I pulled her out, put her on muffs, and she wasn't sucking in water any more
- Today I took the sea water pump housing apart and found that the "key" of the impeller had been stripped (yes, it was a cheap knockoff impeller)
