I have a 1972 Mercruiser 120hp 4 cyl (S/N 411558) the current stern drive is "pre-alpha" and is badly corroded. I would like to replace the stern drive with a used Mercruiser Alpha Gen 1 (also 4 cyl). Is this do-able? I get that the trim indicator system is different but will the replacement stern drive line up with the bolt holes on the current transom plate Will the current outdrives bolt to the Alpha gimbal housing? These may seem like simple questions but I am treading new ground here.
Thanks
