It’s the Volvo penta 225 gas engine 2014 model.... what else you need?Its a 4.3 what?
Serial numbers are best, but at least GXI, GI and model letter
Being a 2014 I'm thinking it has catalytic converters. Would need to read codes on the motor to see what the issue is. Being one beep and shut down might be fuel pump turning off, PCM sees something that is a danger
You the man! Thanks for the help! I’ll check it out ASAP and let you know what I find!Thanks
Have 555ECM, HVS distributor and no CAT's
With 5 beeps I'm thinking failure in one or more of:
IAC, MAP, Coil, Fuel injector or fuel pump
Use a voltmeter and look for 12V at the injectors with key ON. Also check the MAP and coil
