isn't there a rod on the side that ties them all together? its been a while since Ive had a force outboardOk so my findings are it is definitely the choke adjustment. The butterfly is not closing all the way with key. The choke cylinder is up to high not letting it pull the butterfly all the way closed but if I my the choke cylinder down it will not work it tries but just clicks and don't pull down the rod. I loosened it up choked it manually and boom started up first try. My question is there any other adjustments on this thing to change that.
