Whining noise at 3000+ rpm
boatessex
We thought we would write a follow up to our recent Bravo 1 whining noise above 3000rpm . Our engine and out drive had 79 hours on It and apparently had never been serviced . The problem was the 90 weight out drive gear lube that had never been changed ! We were fortunate that a couple of different guys on this I boat forum gave us their experience and advise which was exactly correct ! The original gear lube came out very black and we were lucky to not find any evidence of water or metal particles as they had said to watch for . Thanks to the help guys and we hope this is helpful for the next guy should his Bravo 1 whine .
You should post your follow up cause for the whine sound in your original post with the question. It will help others down the road with the same problem to see what fixed your issue. Right now that post is left hanging. Glad to hear your all set.
boatessex
Thank you ! Our mistake but hopefully we've figured out how to post in the correct area now . Thanks for the well wishes !
