FreeBeeTony
- May 15, 2002
- 3,994
I have twin '95 175 Johnsons w/ the VRO's still connected.
The port engine always seemed to use more oil but didn't really take much note, figured 2 engines couldn't be exactly the same.
We oil usage on the port engine has gotten MUCH worse,
I verified no air leak by installing a clear hose right before the VRO pump (on the gas line), no bubbles.
I then connected a 1/4" ID hose to the oil line going to the VRO pump and marked it every inch.
Made the following measurements @ ~800RPM in neutral
The port engine used ~6" in 36 sec, the stb engine used ~6" in 3 min!
Looks like the port engine is using oil 6X faster than the stb.........
Plan on rebuilding the pump.
Any other thoughts?
Any other thoughts?
