Port fuel injected with throttle iac body. Clearly missing at idle and all speeds. New ecm, new cam sensor.. oem, new crank sensor oem. no vacuum leaks, timing chain inspection is tight, intake manifold was removed and no issues found. Had 7 codes, new ecm and cam sensor corrected those and now no codes but still missing bad on those cylinders. Compression is all at 145-155 no valve train noise, cam looks great. Fuel injectors swapped and problem stays on those cylinders. The intake runners are connected on those cylinders. Inspected intake as thorough as possible and looks new honestly. Spark plugs have been swapped and problems stays on those. Rhinda scanner is what we use. seems like an easy find this issue but has eluded us thus far. Any help from you good people is appreciated. Im sure we are overthinking it all at this point.
