pvanv
- Apr 20, 2008
- 6,577
Yours should be close.Can I use these values?
You could check with CDI electronics if the CD tests bad.I am back to this little guy and coil test showed required 0.3 Ohm on primary wiring and no continuity on both secondary wirings.
This is kind of strange.
So far all bad coils I saw had shortened wirings with no or very little resistance , but not "no continuity'.
Am I doing it right?
I am following the manual.
Another thought: I can get coil for $50+ , but all other things like CDI , exciter, pulse coils are NLA.
Is there anything to replace them if needed or will this be a dead end?
Not sure what you mean, most of my motors have points (old boys). Can you clarify? Tnx.You could check with CDI electronics if the CD tests bad.
Another thing:
After I removed all the "protective" electric tape from the wires I see 2 wire end sticking from under plate. What can it be?
I have only 4 or 5 digital testersIf both cut wires are are coming under the flywheel corresponds to the alternator coil, remove the flywheel and get rid of that particular coil which is producing electricity with exposed cables. Stay just with the exciter coil under the flywheel.
Get a good analog tester with DVA capability and troubleshoot the CDI, Pulser and Exciter coils. Can find aftermarket CDI, exciter coil, don't know about the pulser, will need the part's code to check that out.
Happy Boating
From my picture you can see that manual says it is only 4K and my multimeter is on 20K scale. I think it should work...Secondary to ground is always very high impedance, often shows infinite on ohm meters.
What do your pulser and exciter show?
I wish I knew it before test...When testing the CD, your battery must be 3v or less. If it is 9v, you likely cooked it.
That aftermarket CD may (or may not) be OK. does it have identical connectors? I would ask CDI electronics.
