Hello, I was wondering if anyone has any insights or suggestions. I’m trying to figure out why this motor won’t stay running, it seems to be a fuel problem. The motor won’t stay running unless it is primed consistently. The fuel tank pick up is clean and the hose and bulb are brand new. I rebuilt the fuel pump with a genuine mercury kit and tested it by cranking the engine it seems to be pulsing adequately because it spits out fuel. The fuel filter is clean and all the fuel lines connecting to the carbs. As far as I’m concerned the carbs should be getting fuel. I also inspected all the jets and gaskets on both carbs and they are all clean. The needle and spring seem to be in working order. Could the floats be possibly causing an issue if they are not sitting at proper height? When the motor is running it sounds good and revs nice. One other thing I noticed is that the water jacket gasket needs to be replaced, water does drip by the spark plug holes but I’m not sure if that would be causing a fuel issue. Any insights would be appreciated thanks
