Voltage goes to 12 when the key is pushed. I’m sorry About the dbl post , when I 1st did it I got a message that there was a problem and it could not be posted.Cute new title, there are two issues. You duplicated the original post and you haven't read our rules.
Hookup a meter to the choke and see what the voltage does when the choke button is pressed.
If I am cranking the engine and push the key in I get no voltage at allVoltage goes to 12 when the key is pushed. I’m sorry About the dbl post , when I 1st did it I got a message that there was a problem and it could not be posted.
What is the voltage before the key pushed?it’s like 7 volts
Yes it did startKey switch.
