danielvanalphen
- Aug 9, 2021
- 58
I've restored a 1966 johnson 6hp (cdl- 23e)
I've replaced everything almost everything that I can, Impeller, fuel lines, rebuilt the carb, and have just replaced everything in the magneto so points, condensers, coils, ignition cable boots and spark plugs. The first time I started it after replacing the magneto it ran great and perfectly on two cylinders. However now both spark plugs are producing sparks but the boot and wire for the bottom cylinder are producing a stringer spark than the other boot. The engine only runs on one cylinder now even with spark in the other one and I've messed around with timing of the points and position of the coils and it doesnt seem to make the spark any stronger. I'm genuinely stuck and have no idea why the only one cylinder is firing.
