nola mike
- Apr 22, 2009
- 5,827
So had a (ahem) small issue with my u-joints last month when the clip fell off. At that time replaced just the drive side joint. The drive was new to me, and both joints were replaced prior to the start of the season. It's started clicking again, getting worse, though still only on fairly hard turns. Not sure it ever entirely went away; trim up full turn still made a bit of noise. They were replaced with Moog 315's, which I've used in the past. After leaving the plug out last week (doh!), I pulled the drive a few days ago just to check for water (none). The joints looked fine, felt a little loose but I think it's pretty tough to tell. I should have greased them but didn't. Gimbal bearing was fine (replaced last season). The drive has clicked since day 1, but otherwise seems fine. Seals replaced, pressure tested, lube looks fine. Wondering if I have something else going on that I'm missing?
