Hi everyone.
New member & first-time poster here.
I have a 1999 Bayliner Cierra 2655, Mercruiser 5.7 Thunderbolt ignition & Alpha 3 stern leg. I’ve picked up the (seemingly not uncommon) issue of an intermittent alarm from the temperature sender, usually only when running at over 3,000 rpm. Alarm stop as soon as I throttle back.
The engine doesn’t seem to be running hot at all - dashboard temp gauge is rock solid & I keep checking the engine temperature with an IR temp gauge & it stays consistent as well. When I unplug the wire from the temp sender, the alarm goes away.
So far I have changed the thermostat & temp sender, but the problem hasn’t gone away. I’m thinking the next options are to change the wire from the temp sender to the Ignition Control Module, or to change ICM itself.
I’ve seen a few discussions on similar issues dating back several years, but so far I haven’t come across anything that seems to provide a definitive diagnosis or solution. Some posts have suggested that the alarm is going off because the ICM isn’t receiving a signal from the temp sender.
Any advice or insights will be very much appreciated.
Regards
Al
Regards
Al
