kenny nunez
- Jun 20, 2017
- 3,429
There will be water in the tilt motor. Easy to remove, the brush head is at the bottom so you want to open it up to dry out otherwise the springs will rust away. Good luck
Will do. I already had written them off. I have a spare harness that I won't be sellingGreat news
Pull the starter and alternator and pull them apart. Hose down with WD40. You can save them
Wring harness may have issues in a few years
No. Wonder what I'd get for a 35 year boat that was probably less than $10k new?Do you have insurance? That would be my first thought.
Do I need to pull the hydraulic lines? I don't think I have it in me to flush the whole system in addition to everything else that needs done.There will be water in the tilt motor. Easy to remove, the brush head is at the bottom so you want to open it up to dry out otherwise the springs will rust away. Good luck
I know I can do it. No, I meant I'm running out of steam and want to drink some beer this weekend@kenny nunez , good point
Easier than swapping a 470 for a V6
We can walk you thru flushing the tilt and trim lines snd cylinders
I was surprised at what full insurance on my '89 cost - around $125 a year with a $500 deductible. I was even able to up the value when I swapped in the V6 and added GPS electric motor to bow.Do I need to pull the hydraulic lines? I don't think I have it in me to flush the whole system in addition to everything else that needs done.
Care to share your company? I'm almost 3x that, same vintage boat. It's full coverage and covers the trailer, storage, and some towards towing and roadside.I was surprised at what full insurance on my '89 cost - around $125 a year with a $500 deductible. I was even able to up the value when I swapped in the V6 and added GPS electric motor to bow.
NEVER go without insurance, you don't realize what personal injury lawyers can do to you if you get sued. It will make your life miserable until the case is settled and if the jury makes a large award you will be SOL. Don't know how it is where you are but here in NY, that's how it is.Care to share your company? I'm almost 3x that, same vintage boat. It's full coverage and covers the trailer, storage, and some towards towing and roadside.
Was going without insurance, and decided it was a good idea when I got stuck in reverse at the boat launch, doing circles backwards watching $ after $ wizz past the bow hoping I didn't hit anyone. The kids thought it was funny though... admiral wasn't impressed.
That is the major reason we have insurance now, to cover liability. The other reason is we were involved in a highway accident last fall while towing the boat (uninsured at the time). Other driver was at fault, but their insurance was blaming yet another vehicle for the accident and refusing to pay out in full. That's when I found out that insurance companies can assess their own percentage of liability (in NY anyway). In the end we made out ok, but it was a head ache. Would have been better to have an insurance company battle for me.NEVER go without insurance, you don't realize what personal injury lawyers can do to you if you get sued. It will make your life miserable until the case is settled and if the jury makes a large award you will be SOL. Don't know how it is where you are but here in NY, that's how it is.
Omg I’m speechless, my heart hurts to see these picsApparently my last post was removed because of profanity, though to be fair if there's ever a time to use profanity it's when your boat gets knocked off a lift, deposited on a jetty, and swamped, and then you get a speeding ticket returning from walmart. But we'll keep it civilized this go round. I did see everyone's responses prior to the takedown, so thank you for those.
My original post from last night:
"Had the last of hurricane Ida just blow through. My boat was high on the new lift. Unfortunately, the control box for the lift apparently got taken by the wind, one of the switches was turned on, and dumped the boat. Washed up on the shore, completely swamped. Just found it, it's high tide now. Nothing I can do. Going to wait till tide goes out in an hour or 2 and drain it. Then I'll have to wait for the tide to come back in before I can attempt to free it. Engine was completely under water (brackish). Fortunately, from what I can see the boat didn't take any structural damage (though that's a huge asterisk at this point). Any chance to salvage the engine? Next steps?"
The wind continued to blow today, and was blowing against the tide, so it was still very rough but the tide never came in enough to float the boat. So I'm going to wait for the next high tide tonight (midnight) to try to get it off the beach. Otherwise I'll start digging it out tomorrow.
I got back out there at 5am this morning, and was able to get the boat off the jetty and mostly bailed out and righted (the port side was about 1-2 feet higher on the jetty, and the starboard side was buried in the sand).
What I've done today so far:
1. Drained the "oil". I got about 2 gallons of first water, then oily water. Refilled (only took 2 qt), waited, and drained again. Very little water, and then clean oil.
2. Pulled plugs, pulled carb, sucked water out of the intake ports, put a couple of oz of 2 stroke oil into each port, turned engine by hand (easy), expelled water, repeated.
3. Finished draining boat. There was still a lot of water in there.
4. Removed dizzy cap and rotor, it was damp in there but not soaked. Probably going to replace the ignition sensor.
5. Wiring. Oy. All the fat positive connections burned off. Battery to starter, both ends of alt wire, the other pos alt wire, red/purple off the slave, red off my fuel pump relay. Cannon connector had corrosion on the red wire. I think that's it. Going to make it tough to get it started, which I won't have a chance to do until tomorrow afternoon. I have a spare helm wiring harness from the donor boat, and I have at least 3 engines sitting around with harnesses. I'll replace all that after I hopefully get it running.
I should have at least got the water out of the pots, oil in the cylinders, and clean oil in the bottom end. I'd like to at least turn it over a bit with the starter to get some oil to the valve train, but I'll do what I can.
Debating fixing enough wiring to turn it over tonight. Think I'll do that. I think I can remove the starter, there's limited access but I can reach the bolts. I'll replace that and the alt before we go back to prime time. I'll deal with the fuel system later. Will pull the drive and see how that's looking. Not sure I can do anything with the gimbal, it's permalube.
Warning: NSFW photos/video
View attachment 349035View attachment 349036View attachment 349037
