Bourbon1792
- Sep 26, 2021
- 5
I am near completion of phase 1 of my restoration project and have run into a problem.
During the restoration of the instrument panel, I discovered many of the wires disconnected or modified. Although I have an OEM maintenance manual, the wiring diagrams do not match my instrument panel. My greatest concern is how the coil wire (purple) is connected to the ignition. It appears that the purple wire was attached oil pressure gauge and then, a jumper to the ignition.
Problem: The engine cranks when the key is turned, but no spark. I gone through all "no spark" trouble shooting procedures and voltage test of ignition components. I am concerned that the problem relates to improper wiring from the coil to the ignition switch. A detailed wire diagram for the instrument panel would prove very beneficial. Thoughts? Advice?
