Panhandle Nick
- Jul 18, 2021
- 73
2009 4Stroke 15hp. NSF 15C. Nissan
I have spark. I have fuel out of the fuel pump i have fuel in the bowl of the carb. With the carb off, in my hand, with fuel in the bowl simulating throttle, i can see and hear the fuel being injected into the carb throat. Yet this motor will not fire off and run. I did follow the advice of one poster and remove the plugs and squirt fuel into the two chambers, replace plugs, prime fuel line bulb and attempt start. It did something it had never done before, the starter spun up and then the solenoid dropped the gear from the flywheel. Previously it would just crank and crank and never start so that gave me hope that it was a fuel problem. But after removing the carburetor and visually inspecting how it squirts fuel I have my doubts. What could this possibly be?
