FORCE 85 HP (1989) 856X9F - new ignition...desparate
TomasoPajaco
I bought a boat with force 85 outboard 1989 model 856x9f, the key ignition is so old that the plastic pretty much fell apart when i tried to turn the key, i purchased a new ignition key with hopes i can do an install myself, i looked at the wiring and its a mess and now im stuck, can someone tell me how to connect these wires, i looked this up on net but its all sorts of graphs and pictures and i cant seem to find a match anywhere, all help sincerely appreciated!
Nordin
Terminal strip engine. Keyswitch.
Yellow wire S terminal
White wire M terminal (one of them, does not matter which one)
Green wire C terminal
Red wire B terminal
Blue wire M terminal (the other that is left)
A terminal at key switch is for auxiliary, hot in RUN position.
The M terminals are shorted to each other in OFF position and are wired so the white wire from engine terminal will ground out to stop the engine..
If you have a VOM or a continuity buzzer you can trace each wire to be really sure.
TomasoPajaco
Red wire B terminal
Thank you You have no idea how helpful this is one if this is 1 question though what happens with the blackwire that's coming out of the block
Nordin
Black wire from head is from the overheat sensor and goes to terminal "overheat" at terminal strip.
The sensor is a bimetallic sensor and when overheat it ground out.
You can wire up a horn or a light as warning for overheat.
Connect a wire at A terminal at keyswitch (hot, +12V) in RUN position to a horn or light.
Then connect another wire from horn/light to the "overheat" terminal at the engine terminal.
If overheating the sensor will ground out and you got full circuit to the horn/light and it will go off.
jerryjerry05
Ignition
TomasoPajaco
It probably is not much but thank you for all this, i hooked up all the wires and the motor started, thank you again!
