Water in cylinders
jerryjerry05
1986 200hp
Starts and runs then gets water in the 3 cyl on the right(maybe the left???)
That's all the info the owner told me.
Sea Rider
Thanks, head gaskets replaced this year.
Retorque them to factory specs, if the motor counts with exhaust covers, replace both side gaskets for new ones and retorque them after some hours of use. Mating surfaces must be impeccable clean to seal properly and avoid water intrusion.
Happy Boating
Faztbullet
Foam cast block ...no exhaust covers. Make sure correct gaskets used, not 3L on 2.7L block
Faztbullet
Forget what I posted above as for different forum. If your getting water in bottom cylinders most likely the divider plate or power head gasket blown.
