Thanks gm280.Seeing the NUMBER of clamps, I'd say someone is a wood worker as well. Once you apply the epoxy and it soaks in and cures, whatever twist or straightening you applied via the clamps, is how it will end up. So nice work. Keep posting those pictures. You know without pictures, it never happened... lol
hadn’t heard from you in a while.
I don’t claim to be a woodworker, but I have many tools and 30+ years in building industry/construction. My specialty is industrial/commercial electrician.
I have made my mind up to build this thing back to the best of my abilities.
I am taking my sweet time and doing things time and time again, building off what I see and improving on that. (When the light comes on.) Hey there maybe a better way.
the bullet proof transom is prime example of this.
you can see how simple it started out and how it morphed into a overbuilt monster.
if it ever starts rotting, at 3” thick and kneed into the hull it’s going to take a long time to show trouble.
the same with these stringers.
I turn my 16 grit disk upside down and follow the hull cutting the underneath side of the stringer, contouring it very closely to hull changes,
I will seal the bottom of stinger later as I’m adding 1 more layer 24 oz back close to transom.
but fully encapsulated the way I’m doing is and even more glass to come with tabbing, this all should last crazy long.
Oh and I bought a bench plainer so look out…
thanks for the reply.
Lectro88
