Bourbon1792
- Sep 26, 2021
- 5
1970 Mercruiser 120 HP with inboard stern drive (SN2795699). I removed the lower gear housing to replace the impeller. As I prepared to assemble the gear housing to the driveshaft housing, noticed when rotating the propeller shaft counterclockwise, the drive shaft does not turn. I turned the shift shaft counterclockwise as far as it will go, while at the same time, turning the propeller shaft counterclockwise... I can feel the gear wanting to engage, but the won't. Any ideas?
Thanks, Tom
Thanks, Tom
