What am I looking at here?
Hott
Picture is a 2003 Evinrude Ficht 150. Owner says a cylinder has a hole in it the size of a dime. This picture shows 2 holes, but is that the cylinder head? No mechanic here...lolScreenshot_20211231-174008_Messenger.jpg
GA_Boater
Happy New Year.
Is this the same motor with 90 compression across the board? Bad camera angle to tell if that's the hole, if it is a hole.
Hott
Happy New Year.
No sir different boat, owner stated the hole was just above the second cylinder. He said compression in all cylinders were close. Could this be a water jacket that failed?
Remove sparkplugs.----Turn motor over.------Do you see any moving parts through that hole ?------
tphoyt
Looks like a whole in the crank case to me and I’m looking at that crank shaft but I have had a few cold ones. šŸŗ
F_R
Well if it has compression on all cylinders, the connecting rod must still be attached, so something must have gotten into the crankcase, and the con rod bashed it through the case.
Crosbyman
same way my merc 20 died years ago....hole punched on the side of the crankcase.
R.I.P.
Faztbullet
Skirt on piston broke or rod bearing failed cause rod or piston piece to ventilate block. Not worth much ..it a parts motor and not feasible to repair
Bought a 15 HP motor with hole in the block..------Parts I thought.------But a metal plug had come out of the crankshaft.------Popped the hole in the block.------Machined a new plug and installed.-----Used " lumiweld " to repair hole in the block.-----This was about 15 years ago and motor is still in good running condition.
