Jason_SJC
- Oct 17, 2021
- 19
She's a salty mess. I had a frozen forward prop that I had to cut off the outer shaft. Then I had a frozen retainer ring that over 1500 ft lbs of torque would not budge. I cut that out, too.
Now I have a 5lb sliding hammer attached to the bearing carrier and I'm beating on it like crazy, to little or no avail. My depth gauge says it's moved about an eighth of an inch, but I'm not sure about that. We've soaked it in PB Blaster for 5 days straight, after removing as much crust as possible from the housing/O-ring interface using a sharp awl.
While trying to move the retainer ring, we heated the case with acetylene to ~600F. I didn't want to do that for this part just yet, in case the heat would cook out the penetrant. Not sure if those tricks are mutually exclusive, or if I'd be well served to purposefully burn the O-ring material away from the housing.
Am I missing something here? I'm about ready to cut this part out, too, but it's $600+ new.
Current Situation:
Prior fun removing the thrust plate:
Current Situation:
