LED safety issue
Grub54891
Heard about it a bit in ABYC class but haven't had a problem with it around here. Possibly when they first came out, they were not as good as they are now?
Led lights.-----Just another modern folly for some applications.-----Picture traffic lights in a remote and northern locations.-----Regular light bulbs produce heat and keeps them clear of snow and ice.-----Same goes for tail lights on trucks and vehicles.----There will be collisions.
I understand in some areas there are folks ready to respond to clear traffic light issues..-----You know the ones in tubes.-----They tend to fill up with snow.
Just use ---google or you tube to see issues with LED traffic lights in areas where there is snow.-----Winsor ( near Detroit ) has had issues.----Known to have issues with LED traffic lights !!
There you go.-----Just read an article on safety to do with ---" infotainment " and controls on new vehicles.-----I can not understand how authorities have allowed it to develop with huge gps / video screens to distract drivers.----I have 2 vehicles with wiper controls on one on the right side of steering column and the left on the other.----Light switch on the dash on one and on steering column on the other.-------Us old folks do not need the electronic wizardry to get around.
440roadrunner
As a long time radio amateur (who is no longer very active) I "fight" this kind of thing all the time. Many MANY components we deal with every day affect radio reception at some level. AT HF one of the worst offenders in my home was my old cellphone charger--a tiny switch mode charger that created havoc on HF from the AM broadcast band on up through 7 Mhz (the amateur 40M band)
Another aspect that diodes--whether LE(diodes) or some other type, or any other solid state digital device containing transistors--which can ACT like diodes, can be the cause of (one term) "external mixing." This is in other words the "crystal radio effect" or also called the "rusty drainpipe."
For those of us who have seen/ heard this, and worked in the industry, once example is this:
You are doing a job/ install/ repair at a radio site, with multiple transmitters. You tune in a weak signal on your wide-band hand held radio, which you carry with you for testing as well as communication. You take two screwdrivers and rub them together. This "makes" a poor contact "crystal radio" effect, and causes various active transmitters at the site to develop spurious mixing products both harmonic and sum/ difference products of either or both transmitters..........AND JUST LIKE THAT you have noise in your receiver.
There are LOTS of electronic devices that can cause interference to and from radio communications.
Another "good" example of how bad things are is the "new" digital TV. "In the old days" we had ghosts, noise in the audio, abberations of various kinds on our TV tube. But now we don't SEE those--the digital TV simply blanks audio, freezes, or the display goes black. BUT THE SAME types of interference that existed "then" still serves to disrupt over-the-air TV signals now!!
