I have a 2004 Johnson 90 (model j90PLSRR/ Ser. 05070640).
Engine starts, idles good @1100rpm in driveway with muffs on. Revs up smooth, no issues. When at boat ramp, it will start, idle, rev up very smooth in neutral, will stall immediately when put in gear (forw.or rev). not “tapering off”, it’s an immediate stall as if you hit the kill switch.
Recent History: Less than 1 hour on Carb rebuilds (ran great on the test run after) then the VRO pump failed, had it replaced at shop. Replaced the fuel/water separator filter. I have had this issue since I picked it up from the shop. Tested compression 130 on all 4 cylinders. No obvious signs of fuel leaks or vacuum hose wear areas or cracks. When starting, sometimes the diagnostic system (oil,temp etc. lights) will flash and beep (never did this before) I have now missed 3 bass tournaments due to this (2 being classics). Really getting frustrated. Any suggestions would be very appreciated.
