giorgia1954
- Feb 21, 2022
- 6
Hi, new to boating and just recently got a boat with a 1998 evinrude 35hp 3 cyl. The day we got it we took it out for a little test drive for 20 mins and it went fine no issues. Then took it out again and started up fine out on the water then within 5 mins the water temp light came on and went into SLOW mode! Then when we turned off the engine and it wouldn’t start. Then replaced thermostat and greased the prop shaft, no need for water pump because water coming out tell tale? spark plugs are all good, carbs look good. Started it up and it fired straight back up let it idle for 30 mins with hose and no water temp light issue. Took it out again and same water temp issue happened again out on the water. Again turn off engine and it doesn’t come back on. Ordered a new impeller so hopefully that will help just wondering if their could be any more possibilities or check overs we can do with this water pump issue? Thinking could be a timing sensor issue maybe, does anyone have an advice on how to test them? thank you any advice kindly appreciated asap!!!
