1987 Starcraft islander 190v?
87Starcraft
can't beat that deal! I thought it was galvanized at first. is that 3/16 or 1/4" thick aluminum angle?
One side is 1/4” and the other is 3/16”... But I do have a question about aluminum alloy. The angle I used to tie my transom to my stringers is aluminum alloy. The very next day someone at work brought me 100% aluminum angle. Do I need to worry about aluminum alloy?
87Starcraft
Getting the splashwell reinstalled was the hardest thing I have done yet. A combination of not clamping the transom when glueing together and all the epoxy and fiberglass cloth I used in this area made getting the splashwell and trim back on very difficult.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Nothing like a bit of elbow grease and gentle nudging by Mr. Hammer to get it done!!
SHSU
87Starcraft
moving right along here. Hoping I will have her in The water within the month. Putting the engine on today.
SHSU
Looking good. Original motor going back on?
SHSU
87Starcraft
SHSU
Yes sir. The 1987 Johnson 110 had 120 compression on all cylinders. Starts right up every time. I had a mechanic look at it at time of purchase. I rebuilt the carbs, although they did not seem to need it. Great motor. Maybe a Honda 150 one day.
87Starcraft
So... the fuel cell issue.
This was my crack at replacing the rotted wood and pour in foam method. Fabricated these platforms from a construction ahead road sign.
SHSU
Definitely a night and day difference. If you have room, suggest some kind of rubber cushioning to keep the tank from rubbing a hole where it contacts the aluminum you are adding.
SHSU
87Starcraft
SHSU
I have a couple of old rubber blankets from work I’m going to put down. Free rubber, free aluminum, about $2.00 in rivets. 👍
SHSU
Nothing like rehanging the motor!!!! Project coming close to a water test!!!
SHSU
87Starcraft
Does anyone have pictures on how the cuddly cabin comes out. Or the first piece that goes in. Is it the wood or the aluminum structure?
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Im late to this party, but just in time for the best part - a splash!! Haha. Nice work. Wish I had access to free aluminum during my build.
87Starcraft
Haha not a lot going on. Wish I could do a full rebuild. Just trying to stop all the corrosion and get it on the water to catch some fish.
Moserkr
When you get it down to the bare hull, patch holes, replace the transom - thats basically the start of the full rebuild. Once your decks are solid and back in, the rest can be rebuilt as your money and time see fit. But you are setting the stage for a solid boat for many years. I still have work to do on mine, but she got back on the water in less than a year.
