Yeswhere you able to drop the gc a bit & flip it over and drain the Gibbs down the shaft to soak the splines ...??
Lower unit is completely off
The young man said that he had it running and that's when he noticed that it wasn't pumping water and shut it down in a test tank. I replaced the tiller handle assembly and found that a 1986 Johnson tiller handle worked for a perfect fit. So using a 5lb sledge hammer head as a slide hammer, will work ok?As motors get older and older there will be more of these stuck driveshafts in my opinion.-----Folks rarely take them in for authorized service like they did 40 / 50 years ago.-----Cost of labor scares most folks.----Electronic ignition means that motors usually start and there is no reason to visit the shop / do any maintenance.
I will run a compression test, there is no discoloring at or around the surface of the head.Any discoloring of paint on the cylinder head ?-----I suggest a compression test on any motor that is new to you, if only for future reference..----Avoids you spending money on a dud as is often done.----Seen it many times.----Just because a motor " runs " does not mean it is in good condition !!
