Hi, I have a Mercruiser 3.0 gen II. Shifter interrupter switch was stuck and replaced.
Nothing else was changed. Now the shift interrupter switch is not engaging. On the shift interrupter plate I have tried all possible settings by turning the cable adjuster nut all the way in and out also the thread on the cable in and out. Only have been able on certain settings to have the switch engage when shifting to reverse. Shifts perfectly into Forward, Neutral and reverse, just not activating the interrupter switch Should I be looking somewhere else ?
