JASinIL2006
- Feb 10, 2012
- 5,744
Well good news. This morning the peanut butter seemed to have cured quite well. I also have a 80 degree day today should help finish it off.
I used 1.5% mekp with this poly. It was a middle ground for what this was rated too. I have to mention it does not exotherm like vinyl does. When i mix up some vinyl i do it at 1.25% and within an hour its gel at least already. Yesterday i checked the poly after 4 hours and it was cool to the touch and still pretty liquid. It must have really kicked overnight though. Only a minor Tack to the very top and i have to tab over this anyways still.
Sounds like maybe you were toward the light side of the MEKP-to-resin ratio. When I was glassing with polyester, the mix would get warm as it kicked, and it usually took less than an hour to reach full hardness (I imagine it continued to cure after an hour, but for all practical purposes, it was hard within an hour, often less). I don't know if vinylester has a more engergetic reaction, but it sounds like you were either a bit light on MEKP or the ambient temps were low for the mixture you used. Either way, it sounds like it eventually kicked, so all is well.
By the way, nice work on the transom. That looks really good.
