this is a 1981 weldcraft sunhatch with a 305ci motor and mercruiser outdrive.it started running hot and steam blowing out.there was water in one piston and bent a push rod.I had the heads resurfaced and a valve job as well.upon starting it up when the thermostat opened water was dripping out of the manifolds both sides and steam blowing out. the elbows to the manifolds were very hot.I shut it down so i would'nt blow a gasket again.both manifolds have cracks and dripping slow.
you buy new exhaust manifoldsMy manifold is cracked and engine is overheating. I replaced the head gaskets and need info on how to fix this problem.
you can not fix a cracked manifoldOk I will start with the impeller. Can the cracks be repaired or do I need to replace them. Also where can I find manifold replacements.
