flyingscott
- Apr 8, 2014
- 8,299
What temp is this motor running at? If you have water coming out the exhaust holes you more than likely have flow through the motor.
Well I took it out to the reservoir and backed it in and you might know it wouldn't start this 22° here in Ohio I don't use starting fluid I've been told it's hard on two-stroke motors so about 3 mi away from Walmart I'm going to get me some carb cleaner headed back to the water but a good sign when I tried starting to turn it over it paid and it seemed to be a steady stream which is really a good sign I'll keep your boys posted and boys are really appreciate all your inputThis has been an adventure for you for sure. That black stuff could be impeller material that could be clogging things up.
Removing the power head is not a big deal but there is always a chance of breaking bolts. Just take your time if a bolt doesn’t feel right Don’t force and use penetrating oil and heat to try and work it back and forth to break it free.
Best
