CLi87
- Sep 21, 2018
- 231
Hey all, I know this has been discussed a lot but I wasn't able to find my specific answer. My symptom is the common engine dies when shifting into gear problem, either forward or reverse. Most posts reference either the shift switch itself or the lower cable as the problem, I believe it's my shift switch as when I manually push on the lever up or down quickly, the engine dies no matter what. My question is how exactly does the shift switch work? Because looking at it when I shift into gear, the roller pushes the microswitch down so wouldn't it always be engaged while in gear and only disengaged while in neutral?
