Roadking57
- Jul 21, 2021
- 155
I did Sir! Escorting airplanes with motorcycles! Best of two worlds!Welcome home.
You you had a Blast.
I'm hoping so. I repainted a 14ft Aerocraft v bottom with a 40hp max rating. I want to put a 25hp on it. Since I cant seem to order a new one Im wanting to get at least one of these two johnson 25's on my boatGreat motors when they run good. I liked my 71 so much I picked up a 70. The early 70ās 25hp OMCās are super light weight and even when they āact-upāā¦they sill managed to limp back to the dock.
I'm getting my Late Father in Laws 25HP rude in running order for brother in law. I know it's sat at least 10 years. Did the carburetor, fixed the screwed up out adjustment shift shaft and now rebuilding and resealing the lower unit. It sits on a StarCraft 14ft V bottom.I'm hoping so. I repainted a 14ft Aerocraft v bottom with a 40hp max rating. I want to put a 25hp on it. Since I cant seem to order a new one Im wanting to get at least one of these two johnson 25's on my boat
73what year is the rude Clemsonfor?
I'm pretty sure that's his plan.Rust on the reed valves would make me do a total tear down.------Opinions do vary on this approach !
YikesYes Sir! Rings have arrived!!
Began removing powerhead.
Been working on the 73 in front of the shop. Moved her back to bench area next to the 70. Thats when I noticed the 70 is in fact that darker forrest green, and the 73 is that gold/green. both are faded quite a bit.
Ordered a new tankless water heater. Wont be here until monday. Until then I get to play with boat motors![]()
