Moserkr
Chief Officer + Starmada Splash Of The Year 2021
- Nov 23, 2020
- 883
Will have to check in to my motor thread again soon, cause I was able to do a little tinkering today. Started off by finally doing my ole girl some justice and put some much deserved decals on.
Then I tinkered with the motor and found a few issues. First, fired her up as she was and had the same surging/lack of fuel issue. Squeezing the bulb helped. So I disconnected the new sierra fuel filter/water separator and put an inline filter on. I found the quick connect to the side of the motor leaked air as well, and also found the gasket around the carbs had gone bad. Considering it was not that old was disappointing, and I was lucky to have another on hand. Fixing those issues got rid of the surging and she actually ran great on the muffs - idled fairly smooth.
So next test was in a trash can. She started surging a little and would not hold idle, only higher idle held. But there was a slight ticking sound too, not sure why. Also saw a lot of what looked like fogging oil inside the trash can, maybe from winterizing her?
Need to go through the manual some more and trouble shoot again. Racerone in the motor thread mentioned checking the flywheel (I think), so Im guessing I may have a timing issue. Will have to order some tools and try again. One of these days I will figure it out, but at least she fires right up still.
Got new gubment tags too.
