Rivergator
- May 7, 2013
- 232
I am in the process of replacing the steering cable. The old cable was a Teleflex SSC12418 cable which was a bit too long. I am going to replace that cable with a Uflex M86 cable which is less expensive and has excellent reviews. My dilemma is I don't know how to order that cable not knowing if both companies apply the same standard determining the length of their cables. So here is what I measured. Starting at the helm pinion gear and loosely routing a rope from there up to the big nut on the P/S unit, which is 14.5' see picture #1. The distance from that big nut to the end of the SS rod, where the rod connects to the P/S unit is another 17". See pic #2. The position of the steering arm (drive) is dead center see Pic #3. What do you think this is called, a 15', 16' or 17' cable?
