bluebackfisher
- Mar 4, 2020
- 50
I Have a 1992 Force 150 hp outboard and it has 3 carbs and 5 cylinders. Could someone tell me which carb supplies which cylinder or cylinders?
Thanks for the reply! Do you sometimes adjust each carb with its own setting in order to get the motor to run the best, or should all carbs be adjusted the same?Top carb supplies the top 2, 1&2
Middle carb supplies the next 2 3&4
Bottom carb supplies the bottom One #5
I though that was a 125 block with an extra cylinder on the bottom.The initial setting is 1 1/2 turn out.
Then they get adjusted running at idle in the water, in gear.
I thought the top carb fed #1 and #2
The middle carb(little one) fed #3
The bottom fed #4/5?????
Those motors were powerhead rated at a time when every other motor was prop rated. Did you know the 125 force was 107 at the prop.Scott. Don't get mad but your wrong about that too
You ever run one?
