Hello all and thank you in advance.
Just returned from overseas (military). Had my ‘81 Johnson 25 Model J25RCIM in storage, winterized. Cranked first pull.
PROBLEM: fuel lines were dry rotted and leaking
REPAIR: changed fuel lines
Ran great for a few trips. Then,
PROBLEM: severe surging at WOT. Stalled a few times. Then couldn’t go WOT without dying. Idles great.
REPAIR: new fuel pump. Carb rebuild, no shellac, did have black stuff in bottom of bowl. Figured it was from the bad fuel lines. Very clean otherwise. Checked reeds. New spark plugs .30 gap per everything I could find online. Old plugs were worn bad but perfect color. Added fuel filter from tank and after fuel pump. Re-adjusted idle mix.
RESULT: still idles perfect. Still surging at WOT. No stalling now. Ran this way for a few tanks of gas. Still surging though.
REPAIR: fuel flow out of tank hose fuel filter good. Removed filter between pump and carb (figured two maybe too many). Took apart pump (it seemed poor quality, made in China, not Johnson, but it seemed fine visually). Took carb apart to check for contaminants and plugged main jet. Carb was perfectly clean. I noticed the needle was sticking slightly. Valve seat seemed to have burs where the needle tip seats. Polished with q-tips and jewelers rouge. Perfect seal now, no sticking. Re-adjusted float, everything seems perfect. Not flooding engine.
PROBLEM: Ran it again. Still surging
. Perfect idle. Pumping bulb while WOT…no change. Pulling choke knob a very small amount while WOT…runs great, no surging. Push choke back in, then would stall out and die if opening throttle more than idle.
Pulling choke a small amount while at WOT does not affect throttle linkage. It only closes the choke butterfly ever so slightly. (I thought maybe the linkage was out of adjustment and choke opened it to WOT, but no)
The fuel pump is still suspect to me. But no change when pumping the bulb. So that dosent make any sense to me.
I don’t know what else to check or what could be causing the surging and/or stalling.
Sorry for the lengthy read. I wanted to post all relevant info.
Please help. Again thank you.
