Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
fuel filter empty and look at contents
ignition system what is condition of cap rotor plug wires and plugs. Assume you have a thunderbolt ignition . May want to look at sensor in distributor especially if it has the exposed terminals which is the older design.
try opening gas cap when this happens might be the vent line is plugged and after a while it pulls a vacuum on fuel tank
possible carb rebuild but wouldnt think it would run ok for an hour if carb was gummed up
