Recently acquired a 1981 Johnson 15hp and replaced the water pump/impeller due to weak stream coming from the tell-tale. After replacing with a new pump/impeller, it still had a weak flow. I ended up pulling the power head from the case. I removed the plate that contained the inlet and outlet lines that bring water into the power head, for it to be pushed out. First thing I noticed was a rubber grommet that was broken up and wedged into the opening of the water inlet line. (Culprit of the weak stream I hope?) What concerned me, is that there is a lot of oil deposit inside of the area that goes up into the power head. I would assume that should be pretty clean, as water should be the only thing cycling through the power head to cool it down? Am I right assuming that? IF that is so, I assume the seal around my crank shaft is faulty and would need replacing. (There was a little bit of oil build up between the plate of the water pump and the foot where the shaft enters, however I did not notice any on the inside of the pump or impeller.) I know this is long winded and hope someone can understand what I’m trying to say and could offer some input. Thanks!
