These days I am working on my back up engine.
1991 Force 90 HP, 3 cylinder
The top piston position is at 0 deg correct.
The full throttle is set at 28 deg with help of timing light.
The idle mixture is set 1 1/4 turn from touch position.
Idle speed is set as the mark is right below the touch point.
When I try to start it, it can first run for 3-4 sec and then there is a huge pop sound and the engine stops. It dies every time like that.
What could be the reason of that? The used motor comes with a mess of the wiring even with the 2nd coil connected to the first cylinder. I double checked the wiring from trigger - CD - coil, with the wiring diagram on the engine.
The engine sounds like back fire. Please advise how to diagnose this problem.
Thanks.
FYI, the compression is super good for all the 3 cylinders.
Thanks.
