1990 MeriCrusier 3.0
K.Runyon12
I have a 1990 Mericrusier 3.0 inboard. It turns over but it doesn’t always crank. I am looking for some possible help. (It has a brand new starter on it and brand new spark plugs.)
dubs283
Turn over = crank.
Are you saying the engine turns over/cranks but does not always start/run?
Or
The engine occasionally turns over/cranks, but not always?
achris
More fish than mountain goat
Yes it turns over/ cranks but not always
You need to set up a few test points so you can immediately check things when the fault shows.
Set up test points on the starter slave solenoid and the starter motor.
Chris...
