Swedefj40
- Jun 9, 2018
- 204
So I took my (1995?) A1G2 off to check my gimbal bearing and noticed that the input shaft (u-joint) bearings were really rough and hard to turn. I took it to the local Merc mechanic and after looking at it said that I should think about buying a new leg. He said the lower half seems good but he figures that there was probably some water intrusion from a bad bellows at some point in the past and it will have probably compromised the lower unit as well. I'm trying to decide if I just get the upper half (which had obvious issues) rebuilt or buy a whole new leg. The mechanic said the cost of a rebuild might justify getting a new leg. If I decide to go the new leg route, do I go with a Merc product or aftermarket (cheaper) like SEI? The mechanic said not to go the cheap route as they're notoriously unreliable and have been known to have issues with only a few (40) hours of use. Opinions please.
