Hey everybody, long time reader
Here's an interesting one. 1983 50hp johnson 2-stroke 2 cylinder. Had it out for fishing opener this year and worked great. I was boating over to the landing to trailer it, i had it at full throttle for about 5 minutes waiting for the trailer to show up and it suddenly died. Went from full throttle, to not working immediately. No loud noises, no mysterious blue smoke, still plenty of fuel and plenty of battery. Had my trolling motor limp me the rest of the way and on the trailer it went.
Problem: Will not start no matter how much starting fluid, fuel in the carb throat, or turns I try. Will not try to fire, will not fire at all.
Problem: Fuel will not feed into top cylinder, spark plug consistently dry
Here's what I have found:
- Top carburetor was cracked in half
- one of the nuts attaching it to the motor backed out and caused the carburetor to rattle a little bit, and the carburetor actually split in half.
- Replacement carburetor installed, cleaned, float leveled, and gaskets inspected.
- re-built bottom carb as well
- Fuel lines, fuel pump all working properly
- fuel is getting to bowls and filling them, no apparent air leaks
- bottom cylinder pulling fuel well, consistently wet spark plug
- Good spark
- blue, hot spark in both cylinders
- replaced spark plugs just in case
- Flywheel key still intact, timing should still be ok
- Reeds (top and bottom) look great and appear to be sealing properly
- Compression test:
- top cylinder: 90-100 psi, takes 3-5 strokes to get up to pressure
- bottom cylinder: consistently 120ish psi, 2 strokes and pressurized
- Inspecting head or water gaskets
- Inspecting piston rings
