Hi, I have a MCM 4.3 Litre Mercruiser, Thunderbolt Ignition engine. Engine failed to start after the kill switch was deployed while running. I returned the switch to the run position. It will crank, it appears to be getting fuel. Will not start. Serial no is L355976. Is there a procedure/process available to follow to trouble shoot the ignition firing system? Thank you.
